It is currently Mon Aug 11, 2025 8:05 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Plate joining
PostPosted: Wed Apr 06, 2016 4:44 pm
Last Name: Kincheloe
pat macaluso wrote:
Are you guys using tape stretching it across or just laying it down flat with the halves pressed together tight?
Sent from my SM-T350 using Tapatalk
I give it a little bit of stretch. You can tilt one half up a bit while you pull the tape across to get it tighter, or just to help get an equal amount of stretch on each strip. Don't overdo it. The goal is to make sure it's fully closed, not to apply significant pressure. Laying it down flat would probably work fine, but I like the extra insurance of a little tension on the tape.
These users thanked the author DennisK for the post: Pmaj7 (Wed Apr 06, 2016 4:59 pm)
PostPosted: Wed Apr 06, 2016 5:02 pm
I tilt the plates and stretch the tape and use enough of it so that it does draw the plates together nicely.
Note in the pic where the tape is not stuck down in the center?
I built a Spanish Tourniquet and used it on maybe the first ten and then someone posted the tape method. After trying it and getting excellent results when no one in this area wanted my Spanish Tourniquet I pitched it and have not missed it yet.
These users thanked the author Hesh for the post (total 2): Pmaj7 (Wed Apr 06, 2016 6:40 pm) • bcombs510 (Wed Apr 06, 2016 5:11 pm)
